Hello all.
i just received my m2 kit and i want to know this.
i am using WC with holey calibration all updated to their latest versions.
Is the m2 kit “plug and play” in WC or i have to make new settings? ( i don’t mean calibrating)
install the new board, upload holey firm wear, connect all motors, calibrate, and that’s it ?
Please advice !
If the M2 cam with an Arduino DUE board, you can’t load the holy firmware or other Arduino MEGA firmware. It. The motor-shields are also not compatible. WC will not run with the M2-kit.
Makerverse is the software to run with that. https://github.com/makermadecnc/makerverse/releases
i see!
but it had to be something that they should mentioned to users.
the makerverse is stable for use or it is still under development?
i am using my maslow professionally it it is very important for me to know that everything is ok before i make the change.
And a last question. if i skip the new board installation the new z axis will work with the “old” board?
The current per-release is under development and will allow older kits with the Mega to test it. Can’t tell how stable the public release is.
You still have the option to keep using your Arduino Mega and the Mega motor shield, and keep the Due and the Due motor-shield as a backup, till there is more feedback. You still benefit from the faster z-axis.
From the picture it looks like 8mm lead-screw, but there is a tooth-gear transmission as well. Perhaps the setup instructions will give the correct info. Also you might have to add a - (minus) or remove a minus if it turns the wrong way. https://makermade.com/m2-resources/
