Webcontrol or makerverse? Webcontrol either right click or shuttle and select save home. In makerverse, you shuttle the sled to where you want it with the controls then you have to zero the x and y axis with the coordinates in the right column in that widget. The left column is the machine coordinates referenced to the absolute home. While the right column can be changed to a local workspace home for that cut. There may be more insight here
