I have an issue of GC installing. At first I got opengl problem, it stops in the middle of installing
Now I changed PC into a desktop with core i7, radeon hd 4800 video card.
Then opengl issue is gone. I could see the GC program screen for the first time.
(thanks for Geru)
But next, after I installed Python 27, and I ran Python 27 with double clicking .exe in the folder. Then in the black color window, I typed python – version.
It says Traceback (most recent call last):
File “”, line 1, in
NaqmeError: name ‘python’ is not defined
Thank you Bee,
I’m from Japan. I got that from Python27 after installed.
I think installing GC is OK. and python27 is also installed OK but I can’t go to python version check and install python serial.
you should be abble to open the Command prompt and type Python and have it open. It will only do this is it is properly set in the path when using Windows.
Let me know if this resolves running Python for you.
Thanks for everything, Bee.
I’d really appreciate it.
I could install all Python programs by changing directory every time in the command prompt.
I haven’t been there for the life time before
Thanks for the instructions but I couldn’t make it in the last part, " Add the following text to the end of the Variable value: ;%PYTHON_HOME%;%PYTHON_HOME%\Scripts" because windows 10 has a different window from the instructions
But when I type as in below
C:\Users\Username>cd C:\Python27
C:\Python27>python
I could install everything I need to have
Hopefully , I would cut parts tomorrow, really appreciate it
I’ll show the photos later. By the way I’m a cajon builder myself
Hey Yossi, are you sure you want to install python? If you can open Ground Control then you should be done! You don’t need python installed to run your machine.
You have the option to install it and run Ground Control directly from the source code if you want, but we make a portable version every other week so you don’t have to!
Because he is in japan, he may be using kanji type fonts and it may be that it is not playing well with the instructions, when translated. I’ve only worked in Windows once using a Chinese localized system and it was purely by knowing where menu positions were that I was able to pull it off. It sounds like he has made it through the problem. I can tell that the translation is rough we are going through a 2 way translation. I recently started a Python tutorial and had the path problem myself. I had to manually add the path to get it to stick. I was attempting to see if Yossi could launch the portable version. He looks to be OK from the last message.
He is getting ready to cut things now from what I can see.
Since then I have been struggling with checking Ground Control and Arduino IDE thing.
No response of motors, I can see an orange LED blinking on the Arduino board while setting the firmware,
but with Ground Control, no led blinking no moves on both motors calibrating with the Ground Control,
it’s similar to this
So I checked and did it with instructions, but I still have the same issue…
What am I missing?
And while I was doing this, I got Windows 10 update as of Jan 4.
Soon after, Ground Control is shut down, I couldn’t have it until I reinstall that OS.
