I’ve checked the wires and think everything is buzzing but it refuses to move. Any advice?
what kit do you have?
M2 -> did it calibrate? what did you put in for the z axis steps?
classic / jumpstart / metal / eastbay kits -> do you have the z axis enabled in settings in webcontrol?
I have the M2 with the blue sled. I don’t have any additional info in the box or from the seller (Amazon). I’m actually surprised how little info I have. I’ll go back through today and look at the “steps” I entered for the Z axis.
I have the M2 and I read that Makerverse is what I should use. Is that correct?
Yes, you should use makerverse. Were you using something else?
No I was using Makerverse. I followed the instructions that came on the flash drive. No success.
