Just wanted to share some notes from my initial experiences in case they’re helpful to others.
MaslowCNC_Notes.docx (3.8 MB)
INTRODUCTION
In this document, I’ve made a bunch of notes related to my initial experiences with the Maslow. Hopefully they’ll prove useful for future newbies
I incurred the following costs to get everything up and running:
Excludes:
Router models use different names in Europe compared to the US. In retrospect, I should have already known / realized this, but it took me a while to get there. For example, the DeWalt 611 1.25hp (MakerMade recommended choice) is called the “DeWalt D26200-GB 900W” in Europei (which – despite my use of “z” in realized is where I’m based).
From the router manual (for reference purposes):
I opted for the standard frame as described in “Assembly_6.15.2019.pdf”. This was mainly because I didn’t have the wall space available to secure the frame described in “10ft-Standard-Frame-Guide-v1.pdf”.
If I was doing things again …
The picture above is obviously contrived, but it’s intended to illustrate the point. If the edge of the sled was closer to the bottom of the waste board in the negative y-direction (which is absolutely possible), we’d have one brick on one side of the kicker while the other brick is on the other side of the kicker. If one opts to make a pure move in the positive x-direction, the left brick will collide with the kicker beam. This could of course be resolved by changing the angle of the bricks, using smaller bricks etc. Ultimately, I ended up replacing the bricks with 2x smaller format 2kg weights.
Prior to this, the back legs were centered w.r.t. the front legs using a single screw.
When I rotated each of the back legs out, the top corner on each extended beyond the front face of the front leg, i.e. where the waste board is going to be mounted. I ended up having to cut these two protruding pieces off in order to secure a flush surface for the waste board.
This issue could be avoided by offsetting the “rotating screw” relative to the center of the front leg. The most likely reason for this is because the 4”x2” lumber is actually 3.75”x1.5” as already mentioned.
I personally found it easier to leave the legs standing.
I believe the 62” referenced should be 47”:
That said, the actual chain length doesn’t appear to be that critical at this step. I actually ended up increasing the length beyond 47” as it made it much easier & (I felt) safer to connect the spring tensioner between the two sprockets. As a sanity check I used the following figure from step 12D of “10ft-Standard-Frame-Guide-v1.pdf”:
Knowing the top beam is 10’ long, I could roughly calibrate myself as an extra sanity check. I ended up with ~60” which is very close to the 62” mentioned in the instructions. This means the thumb loop needs to be at ~23” instead of 16”.
I initially thought it almost impossible to set the final height for the ring carriage until the frame had been built and everything had been put together. The ring carriage height is set to ensure that the chains are held equidistant across the working area of the board in order to keep to chains and motor sprocket co-planar.
Shortly afterwards I realized it is possible to calculate knowing (in the z-direction):
Total = 15mm + 1.5” + 7” – 3.75” – 0.75” – 15mm = 4”
Actual distance measured from the top surface of the sled to the ring = 3.75”, meaning that if I typically operate with 0.25” material (~6mm), then things are well aligned. If I operate with thicker material, then the ring would need to be lowered closer to the top surface of the sled. I think it’s pretty marginal at this point, so I’m happy enough. I’ve also seen a design (from MeticulousMaynard I think) where the top beam can be adjusted in the z-direction to accommodate different material thicknesses.
I did not see the following per the “Calibration-Makerverse-1_1_2.pdf” instructions:
Rather my connection was simply labelled as “COM6 Microsoft” (no biggie). The actual connection worked fine.
(see http://www.makerverse.com/machines/cnc/maslow/ for help on the calibration)
NOTE: When I initially started the calibration, I was a bit nervous about the z-axis, so I wanted to retract it close to the end of its physical travel. I ended up hitting the z-axis soft limit however but didn’t know what had happened for a while. This is where “Reset” and “Unlock” buttons in Makerverse became my friends.
I also ended up temporarily changing the value of the soft limit as well as completely disabling the soft limits by entering the following in Makerverse’s console window :
$20 = 0
Here, I should probably just permanently change the value of $92 to, e.g. 30mm which then allows me to change the router bit comfortably without removing the router and re-enable the soft limits.
“$92”: {
“name”: “$92”,
“value”: “12.700”,
“units”: “mm”,
“message”: “Z-axis minimum travel safe distance”
This section outlines the calibration values I ended up with.
Chains are 11ft long (=> full length = 3360mm). In the on-line help for the calibration 12ft chains are referenced with the same 3360mm, which is incorrect. This should read a chain length of 11ft. The value of 3360mm which is more important is correct.
Rotation disk radius = 139.1mm (standard M2)
My sled weight (including router + bricks) = 1 stone 10lbs (I didn’t have a scale in kg at the time)
1kg = 2.20462262185lbs => 1lb = 0.4535923699997kg
1stone = 6.35029kg
Total weight = 6.35029 + 4.535923699 kg = 10.8862137
kg to Newton = 9.80665 => total weight in Newton = 106.7572876
I later replaced the 2x bricks with 2x 2kg weights bringing the total weight to 10.2kg = 100N.
= 3012mm (first measurement)
= 3013mm (second independent measurement)
I used 3012.5mm in the end.
= 410mm (do not use !! - first [poor quality] measurement)
= 431.5mm (improved measurement … several repeats confirmed the
same value)
= 713mm
x = ~1mm
y = ~2.5mm
Edge Calibration
This step measures the distance from the edges of the waste material to the sled.
No drilling / milling involved.
Due to the curved shape of the sled edge, there will be an inherent inaccuracy in the measurement that is corrected in the next step.
Precision
Setup: I opted to drill 1mm deep holes 231.5mm from the edge (9.1") of the waste board.
This is to prevent that the bottom of the sled hits the kicker beams on which the waste board is supported (as mentioned earlier)
At some point in time (days after my initial calibration), $102 changed from its default of 472.5 steps / mm to :
“$102”: {
“name”: “$102”,
“value”: “918.750”,
“message”: “Z-axis travel resolution”,
“description”: “Z-axis travel resolution in steps per millimeter.”,
“units”: “step/mm”
I noticed this on 30-May-2021, but I’ve no idea how it happened. I had checked it previously during the calibration setup and it was set to its correct default value.
For subsequent “Precision” re-calibrations I ended up using pieces of masking (painter’s) tape at the approximate locations of the previously drilled holes in order to distinguish the new holes from the old.
Date: 25-May-2021
“chainLength”: “3360.000”,
“distBetweenMotors”: “3014.500”,
“motorOffsetY”: “428.500”,
“leftChainTolerance”: “-0.103”,
“rightChainTolerance”: “-0.197”,
“sledWeight”: “106.800”,
“chainOverSprocket”: “2”,
“rotationDiskRadius”: “139.100”,
“chainElongationFactor”: “0.0000051685”,
“machineHeight”: “1219.200”,
“machineWidth”: “2438.400”
Date: 01-Jun-2021 (with new 2x 2kg weights)
“sledWeight”: “100.000”,
Date 04-Jun-2021 (after using the physical measurement of the waste board and performing a “Precision” calibration)
“distBetweenMotors”: “3011.500”,
“motorOffsetY”: “427.500”,
“leftChainTolerance”: “-0.128”,
“rightChainTolerance”: “-0.255”,
“machineWidth”: “2439.500”
I currently use Carbide Create to define the tool paths (& LibreCAD to create the initial drawings).
Make sure the following settings are used in Carbide Create:
NOTE: The absolute zero in the z-direction should still be set to the surface of the waste board material as part of the initial setup.
Update 02-Jun-2021: I’ve since experienced this error again – even when using the Basic G-Code post-processor on a file that had previously run perfectly before, so perhaps simply resetting the board would have fixed the issue the first time around with the GRBL post-processor.
Update 13-Jul-2021: Having experienced this situation multiple times since, I find that sometimes disconnecting and reconnecting solved the issue while other time re-generating the g-code file appeared to help (I think this was more coincidence than causal).
One of my earliest cuts involved engraving “Hello World” onto a piece of scrap MDF. In general, I was pretty happy with the results, but it was also clear that at some points the wall thickness was insufficient to hold the letter in place. I’d either have to use a smaller diameter bit or increase the font size.
So, then I found this:
These router bits do not appear to be available in Ireland however. They were available on amazon.co.uk, but not for shipment to Ireland.
For now, I opted for the “Cen-Tec Systems Quick Click 95237 32mm Vacuum Cleaner Power Tool/Sander Dust Extraction Adaptor Set (19-58mm)” (see link) together with a standard household vacuum cleaner. I actually only needed two pieces from the set together with some kludging, but I thought the other pieces might come in handy someday anyway for other power tools.
I then used silicone to stick the piece that I cut to the acrylic dust cover as well as mounting the dust collection bracket and feeding a cable tie through it and around the adapter piece for additional support. The silicone has since detached itself.
I might eventually transition to something like the “ONCCI Professional Filter Separator Cyclone Dust Collector Extractor/Vacuum Separator/Suction Vacuum Cleaner Separator with Accessories Set (Typ-1)” but as yet I’ve no real need to do so.
I actually noticed at some point during a “Precision” calibration that the dust collection system was creating a vacuum between the sled and the waste board (no work material was mounted at the time). I ended up turning the ring shown below to adjust the air flow in order to reduce the vacuum force somewhat, but it was still noticeable afterwards.
NOTE: The vacuum cleaner I’m using doesn’t have a variable suction setting.
I’m not sure yet if this is effectively increasing the weight of the sled and perhaps needs to be included in the math?? Either way it doesn’t appear to be affecting the cut results (yet).
I can imagine that during a negative y move, it acts to reduce chain sag but also make the motors work harder due to the increased tension, while for a positive y move, the chain sag increases??
A really nice clamping idea can be found at https://www.youtube.com/watch?v=O-rqf4uSXRE&t=0s (Marius Hornberger). I think this is a really elegant solution which ensures the clamp is always below the surface of the work material for work pieces with thicknesses > 12mm – which really appealed to me.
Instead of using the copper pipe idea from the original design, I opted for M6 x 13mm inserts with a 75mm XY-spacing on the waste board. The main reason for this was because I figured I’d be able to use the inserts for the type of clamping illustrated below should the original plan not quite work as desired (though the clamps would then protrude above the surface of the work material).
M6 insert (see here). I drilled 8mm holes in the waste board to accommodate these guys.
M6 bolt (see here).
Washer (see here).
In order to cover the full waste board, I’d need a lot of them so I “strategically” placed a few to begin with. There are two versions of the clamp in Marius’s template: an original and a mirrored version. I found out the hard way that the mirrored version was required under certain circumstances in order to avoid situations where the handle would otherwise need to be over the material surface in order to achieve locking. The “B” version of the clamp in the photo below is my mirrored version which resolves the described “issue” in those specific circumstances.
Front side of waste board (top).
Front side of waste board (bottom).
Back side of waste board showing M6 insert (with bolt inserted).
I ended up taking the DXF provided and modified it to suit my needs. Installing the clamps is obviously much slower than with the copper pipe, but that doesn’t bother me.
Use the g-code viewer at https://ncviewer.com/ to make sure everything looks ok before starting a cut.
If you don’t want to start from the absolute (0,0), make sure to use these buttons to set a working zero, once you’ve manually positioned the sled where you want it.
I found the following article on speeds and feeds both interesting and helpful (Calculating Speeds and Feeds for CNC Machining – CNC Router Bits). If you didn’t already know it before taking the Maslow plunge, then the Maslow feed rates are probably right at the bottom of the food chain, so most – if not all – of the calculators out there won’t be very helpful.
The max quoted feed rate for the Maslow that I found in various forum discussions is 48 in/min which translates to 1219.2mm / min. “Typically”, people have reported using 30in / min. I’m opting for ~19.7 in / min here.
It’s important to make sure that you use a plunge speed that is lower that what the M2 is actually capable of. Otherwise, the XY movement may start before the z-move plunge is complete. I use a pretty slow plunge speed of < 4in / min.
I was a little surprised I couldn’t find some kind of “best known methods” table for the feeds and speeds people are already using for different materials / thickness / bit combinations. I did manage to find a couple of forum discussions on the topic, e.g. Speed and feeds questions and Shopbot PDF: Selecting the Right Bit; Feeds & Speeds Chart - #3 by zaneclaes together with a reference to a WiKi page that looks like it was intended exactly for this purpose (Stock Materials · MaslowCNC/Mechanics Wiki · GitHub), but is not fully populated.
Early on, I noticed that the feed rate in the x-direction appeared to be slower than in the y-direction. I let this slide for a while, but eventually did a test using the following G-code:
G90
G21
M05
M0 ;T102
M03S16000
G0X0.0Y0.0Z7.00
G1X500.0F500.0
M0 ;T102
Y500.0F500.0
M0 ;T102
X0.0Y0.0F500.0
Z7.00
M05
M02
Move
[mm] Requested Feed Rate
[mm/min] Move Distance
[mm] Move Duration
[sec] Actual Feed Rate
[mm/min]
So even though a feed rate of 500mm/min is reported in the “Status Reports” section of the MakerVerse GUI, it would appear that the physical feed rate is different.
After changing the feed to 762mm/min, I got the following results:
Move
[mm] Move Duration
[mm/min]
0,0 500,0 500 500 48 625
500,0 500,500 500 500 30 1000
500,500 0,0 500 707 60 707
So, in terms of scaling:
Move
[mm] Expected Scaling
(762 / 500) Measured Scaling
The full story can be found at Feed Rate discrepancy in X and Y
I’ve tried 3mm wide and 1mm high for 6mm plywood Result OK
My initial setup (described previously) was all performed on a Windows 10 64-bit system that I also use for everyday tasks. As I didn’t want to be constantly moving the laptop around or having it in a dusty environment, I decided to resurrect an old Windows Vista laptop to run Makerverse on.
While I won’t go into every nitty gritty detail, below are some of the highlights:
sudo chown a+rw /dev/ttyACM0
where “ttyACM0” corresponds to the port name.
| * General tips | * Maslow CNC - The Maker Station Wiki! |
| * G-code viewer | * https://ncviewer.com/ |
| * G-code cheat sheet | * G-Code Cheat Sheet + MDI: Your CNC Secret Weapon |
| * Maslow calibration | * http://www.makerverse.com/machines/cnc/maslow/ |
| * Wood engraving router bit tips | * https://toildrop.com/router-bits-sign-making/ |
| * Clamping Ideas | * https://www.youtube.com/watch?v=O-rqf4uSXRE&t=0s |
| * Clamping Guide | * https://mekanika1.odoo.com/blog/learn-1/the-ultimate-cnc-clamping-guide-22 |
| * Guide to speeds and feeds | * Calculating Speeds and Feeds for CNC Machining – CNC Router Bits |
| * Guide to speeds and feeds | * Stock Materials · MaslowCNC/Mechanics Wiki · GitHub |
A single chain link = 0.25” pitch => 1650mm of chain corresponds to 259.84 links
Interesting read on the triangular kinematics Discussion Regarding Triangular Calibration - #26 by madgrizzle
UHMW tape used to reduce friction between the sled and the workpiece. A sheet of same might be another option.
i This is the router I’m using myself.
Thanks for sharing your detailed notes and insights on your experiences with the Maslow! Your documentation of costs, router choice, frame build, and sled build is incredibly helpful for newcomers like me who are considering embarking on a similar journey. It’s impressive to see how you navigated challenges and made adjustments throughout the process. The tips you’ve provided, such as considering the differences in router models between Europe and the US, and your observations on frame modifications for accuracy, are truly valuable. Your thorough explanation of calculating the ring carriage height is especially enlightening. Your dedication and attention to detail are commendable, and I appreciate your willingness to share your lessons learned. This will undoubtedly prove to be a valuable resource for future Maslow newbies. Keep up the fantastic work!" ![]()
Also you mentioned vacuum cleaner , can I use a regular vacuum cleaner?
Many thanks for your thoughtful feedback. I’m delighted to hear that the notes have proven helpful in some way. I indeed use a regular vacuum cleaner - an old Nilfisk, and I did eventually upgrade to a Cyclone Dust Collector which I’m very happy with. Best of luck on your journey !
