Walkthrough from ordering to cutting your own designs
Work in progress! Don’t hesitate to complete!
Maslow has many strengths. The most important one is that you can bring your own router, hardware and software. The weakness is you have a multitude of ways of setup! Sometimes it is confusing to find the exact information needed for your setup.
Let’s try to make a complete wiki, pointing to the right places of information. Editing this wiki is really easy. At the bottom of the post is an edit button. Edit it just like you would edit any post.
0. Preparation
Check compatible operating systems
Check for compatible hardware, Many tablets have 1 USB port that is needed to power the tablet or you will run out of battery before you finish a cut. This would require a USB hub, powered is usually a better choice when a USB hub is required. Where ever possible use USB 2.0 ports.
1. Ordering material
1.a) Order a kit
1.a.1) Maker Made CNC Classic Kit, $499.99 includes basic kit, ring kit, z-axis kit. You will need to supply the router. Forum username @MakerMadeCNC. Status: active.
1.a.2) metalmaslow’s Metal Maslow Kit, $600 includes a Makita RT0701C router ($500 without router) and several upgrades to the original Maslow. Forum username @Metalmaslow. Status: 200 kits to be offered for sale; orders have not yet started.
1.a.3) East Bay Source’s Original Maslow Kit Forum username @EastBaySource Status: Active.
1.a.4)Maslow Surplus Parts’ Full Maslow CNC Kit Forum username @Maslow_Surplus_Parts. Status: Active.
1.b) Put together your own kit:
1.c) Improvements/alternatives to the standard kit
  • Alternative kinematics:
    *The original Maslow kit shipped with rectangular kinematics
    *Later shipments included the triangular kinematics ring kit for improved accuracy
    *A linkage-based triangular kinematics kit has been offered for sale and is available in the community garden.
  • If you opted for the Bosch 1200 AE, order a Z-axis conversion kit
2. Electronics
Instructions
3. Maslow programs
3.a) Instructions for programming arduino
3;b) Instructions for installing ground control
4. Building the frame
Instructions
5. Setting up Z-axis
Ridgid R2200
Bosch 1200 AE
6. Temporary sled
7. Calibration
From the well known song:“calibration, let’s all calibrate and have a good time”
8. CAD software
Multiple are available:
9. Cutting the final sled
Instructions
Remark: attach the carriages and mount the router before fixing the ring. In that way you can verify the carriages can travel freely around the body of your router. Also push the router down to check if the carriages never touch the body.
10. Post-process your first design
11 Cut your first design
Here’s a question for the community: Do we want to have a “talk” thread associated with each Wiki thread? That way the inevitable discussions about the wiki page which eventually digress into unrelated areas are kept slightly separate. This would be somewhat like the way Wikipedia is organized, though just because they do it that way doesn’t mean it’s right for us. Thoughts?
Wouldn’t the first post just be the wiki, and everything under it the discution?
Is there a way to hide all the post except for the first one? With a button to make it visible ofcourse.
Is there a limit to how big a post can get?
That’s what I would expect. Honestly, I wouldn’t be bothered by that myself, but I thought we should at least have the discussion, so if others feel strongly they can be heard.
