How To: Get Calibrated!
Note: The intent of this thread is to help people get their machines calibrated and answer “frequency asked questions” of the process.
Do this First:
Go to Settings->Advanced Settings and set the Extend Chain Distance based upon the following:
  • If using a 10-foot top beam, set distance to 1651 mm
  • If using a 12-foot top beam, set distance to 2032 mm
The key to the setting is to make it a multiple of 63.5 mm and long enough so you can attach your chains to the sled when the time comes.
Calibration Overview
Unless you are doing abstract art and don’t care if you get curved lines instead of straight lines, you need to calibrate Maslow. Calibration is of paramount importance and is probably the most difficult (and maybe frustrating) part of owning a Maslow. If you do get frustrated, take a break and come back to it. I’ve done that so many times it’s silly.
If you want to understand the technical details of calibration, take a look at this thread… maybe take a look at it even if you don’t care.
The calibration process takes you through a series of steps and questions so that critical parameters of your Maslow can be determined. The more accurate these parameters are known, the more accurate your cuts will be.
This thread is divided into multiple posts where each post represents one step of the calibration process. As the process may change over time, new steps may be added or deleted, but due to this being a forum, it’s not possible (as far as I know) to move posts around. So over time, things may get disjointed.
Step 1: Introduction
This is one of the easiest steps of the process… read what it says and then click ‘Next’ to begin.
So, what does it say?
This walk-through will guide you through the process of calibrating your Maslow Machine.
You can move forward and backwards through the walk-through at any time using the Back and Skip buttons
You can also skip this process entirely and enter machine dimensions in the Settings window
Your feedback on how to improve this process is more than welcome
Click Begin to start.
Frequently Asked Questions About This Step:
What is significant here is that if you have to do calibration multiple times (for whatever reason) you can skip over certain steps if you have already completed it. For instance, if you have done the calibration once and the distance between motors is already known, you don’t have to do that measurement step again, just skip it.
However, there are certain conditions you need to know about before you just skip things willy-nilly. We’ll attempt to explain that on each screen.
Things you need to know before skipping this step:
Nothing, but there's really no reason not to just click begin.
Step 2: Select How Chains Attach to Sled
This step should be easy also. 99% chance if you are reading this, you are using “triangular” kinematics and not “quadrilateral”. Originally, the chains connected to the sled as shown in the figure to the left, called a “quadrilateral” system. This methodology works, but the math is complex and accuracy never achieved what was desired. A few people still use it and Maslow is shipped with a triangular kit now…
Most everyone has either a ring kit or a linkage kit. The theory behind them is that the chains always point to the center of the router bit. This simplifies the math and is called a “triangular” system.
Frequently Asked Question About This Step:
What do I pick, “Quadrilateral” or “Triangular”: Actually, I don’t know if this is frequently asked or not, but unless it looks just like the picture on the left, select “Triangular”.
If you haven’t done this step before, select your chain attachment type. The default is quadrilateral and if you never tell it to use triangular, there’s a 99% chance it will be wrong (since 99% of the people use triangular)…
Step 3: Vertical Height of Motors Above Work Area
In this step, you are asked to measure the distance between the center of the motor shaft / sprocket to the top of the work area. The image on this screen does a fair job explaining what needs to be measured. As mentioned on the instructions, its not critical because this value will be adjusted during calibration (assuming you are using triangular system… which 99% of you are).
So grab a tape measure and measure it. One thing to note is that the measurement is in millimeters. I don’t think it can be changed.
To enter the measurement, click the “Enter Measurements” button. A “touchscreen” friendly box will open up to allow you to enter the measurements. You can type the numbers in if you want… there’s no flashing ‘cursor’ in the input field to tell you that you can, but it works. Use backspace to delete. Remember, enter the value in millimeters
Frequently asked questions about this step
How do I do the measurement? Use a tape measure and just get close. Eyeball it. Just make sure you use millimeters
Well, if you haven’t done this step before, I think you should do it at least once. The closer this number is to your real number, the fewer the number of times you need to run the final calibrations step. Worst case scenario is you use the default value and may need to run the last step another time to get to a final result.
Common mistakes on this step
Most common mistake is entering the measurement in inches or centimeters (I did that once… used centimeters). So… USE MILLIMETERS
Step 4: Set Sprockets Vertical
Ok, this is the first somewhat “challenging” step. Your goal is to set one tooth of each sprocket to the 12 o’clock position (i.e., straight up away from the center of the earth). There’s buttons on the right side you can press to move the sprockets clockwise and counterclockwise. I’m not sure of the value of 360 deg rotate…but it’s there if you want to waste time. Click the buttons (start with 5 deg and then go to 1 deg) to get one tooth straight up. Do that for both left and right sprocket. Once done, click “Set Zero”
Can I just press the “Automatic” button and have it do it for me?
Maybe. If this is your first time or you received a message somewhere that the controller has lost the position of the sled, then you need to manually set the sprocket. If you have done this before and no issues, then click automatic. What I’ve done is to mark one tooth on each sprocket as the 12 o’clock tooth (just used a pencil to mark it) and if that tooth doesn’t go to 12 o’clock, I know something is off.
How can I tell if it’s at 12 o’clock?
Do your best or go to this post. It has a great solution using just a few extra parts.
What you need to know to skip this step
If you are going to skip the next step (measuring distance between motors) then you can skip this one as long as the controller knows where the sled is located. That is, there’ve been no errors saying it’s lost its location or you’ve had chain skips. If you are going to measure the distance between motors you have to do this step.
Step 5: Measuring Distance Between Motors
Out of all the steps, this one causes people the most problems… and it’s really not that hard.
The first thing to do is to READ THE INSTRUCTIONS… ALL OF THEM
Regardless of how you plan to deal with the slack of the chain (over-top feed or under-bottom feed), you will do the distance measurement just like shown:
  1. Place the first link of the left chain on the left sprocket as shown on the image on the left.
  2. Press the “Extend” button. The left sprocket will rotate clockwise and feed out 100 mm of chain. Make sure it doesn’t wrap around the sprocket. I hold that chain and put tension on it during this whole process of feeding out chain because for whatever reason, my chain LOVES TO WRAP.
  3. Once you got 100 mm out, press the “100 mm” button and change the value to “1000 mm”.
  4. Press “Extend” button again. Again, here I hold onto the chain pulling it so there’s tension on it to keep it from wrapping around the sprocket.
  5. Press “Extend” button again.
  6. Press “Extend” button again. At this point, you should have about 3100 mm of chain extended. I think this will be enough to place the first link on the right sprocket as shown in the picture on the right. If not, change the 1000 mm value to something smaller… maybe 10 mm and click it a number of times to get you to where you need to be.
  7. Place the end of the left chain on the right sprocket as shown in the picture on the right.
  8. If you haven’t changed the 1000mm to a smaller value, do so… go with 10 mm… I don’t know.
  9. Click “Retract” until you remove most, but not all the slack.
It’s been reported that during the next step, the chain can come off the right sprocket and smack you pretty hard. It can be under a lot of tension and if it comes off, things might hurt. I’ve only had this happen to me once, but it was while the chain was just starting to tighten up and the end just fell to the ground. Others, however (need to find the post) had it happen further during the tensioning process and can have some force behind it.
  1. Click “Pull Chain Tight and Measure”. During this step, the slack will be taken up and the motor will determine, from its perspective, the distance between motors based upon how much chain is fed out. After it’s done (it’s pretty quick) the chain will slacken up. This will allow you to remove it from the right sprocket. Try to pay attention to the motors and frame during this time. If you see the motors move or the frame flex, you’ll end up with low accuracy so you’ll need to make some repairs to your frame.
99% of the problems on this step is because people don’t use the buttons to feed out the chain… they just drape the chains over the sprocket manually and then click pull chain tight and measure. You must use the extend button to feed out enough chain to get it to reach the right sprocket. There’s no shortcut here.
As long as you’ve done this measurement before and the controller knows where the sled is, you can safely skip this step, but you will also need to skip the remaining steps (except for the very next one) until you get to doing the calibration cuts.
Step 6: Pick Your Chain Feed Arrangement
Pretty simple step. Referencing the left sprocket, if the slack of your chain hangs vertically down from the sprocket, you are in “Chain Off Top” configuration. This is how the early frames where built.
If, however, you take up your slack “horizontally” along the top beam, then you are in “Chain Off Bottom” configuration. This is how most newer frames are built.
Click the button for whichever configuration you use.
Note: The following steps will differ depending upon what configuration you are in.
Which configuration do I pick? Seriously? I just explained which one to use.
If you’ve never picked your configuration before, pick it otherwise you run the risk that the default value is incorrect and the following steps will end in nothing but misery.
Step 7: Review the Measurements
It might be a good idea to jot down the numbers and make sure everything is correct. If something looks wonky, it probably is. (Don’t concern yourself with the numbers in the above picture… these are old numbers from an old frame of mine that I’ve manually messed around with).
If something is off, click the back button to go back and redo the steps that are wrong. If happy enough to move forward, click “Looks Good”.
What do I do if something is wrong? Click back until you get to the step that’s wrong and redo it.
I don’t think it makes any difference if you click skip or “Looks Good”. The settings should have already been saved by this time.
Step 8: Generate Calibration Procedure
Take a deep breath and hold for 4 seconds. Exhale. If you did it right, it should have moved on to Step 9 by the time you are done. If you did it wrong, it should have still moved on to Step 9 by the time you are done.
However, what comes next depends upon whether you picked “Chain Off Top” or “Chain Off Bottom”. So this thread will fork… like one of those “Choose Your Own Adventure Books”. As it stands now, you only need to do Steps 9 - (whatever) if you are in “Chain Off Bottom” configuration. If you are “Chain Off Top” go to Step 10!
Why is this step here? Well, as I mentioned above, the next steps are different depending upon your chain feed configuration so the software has to ‘build’ the steps for you to take. It’s a code thing.
Only that you can’t skip this step.
Step 9A: Remove the Chains - CHAIN OFF BOTTOM USERS ONLY
Pretty simple step. Take the chains off the sprockets because they aren’t installed the way they need to be… Then click “Next”.
Frequency asked questions about this step
Do I need to take the chains off the sprocket? Only if you want things to go well.
Well, if you chains are still attached to the sled because you skipped other steps, then please, skip this step because.
Step 9B: Set Sprockets Vertical - CHAIN OFF BOTTOM USERS ONLY
Didn’t we just do that in Step 4? Yes, and we are going to do it again but this time, through the miracle of technology, you are just going to hit “Automatic”. If that doesn’t set the 12 o’clock sprocket tooth to 12 o’clock, then something is seriously wrong and you need to take a break and come back and start this process all over again. Edit: Don’t Panic! So it appears that the “Automatic” button may have a bug in this step. If the automatic button doesn’t return you to 12 o’clock, go ahead and readjust the sprocket through the buttons..
If it does work, then click “Set Zero”.
Can I use “Automatic”? Yes. Edit: Don’t know for certain. If you find it doesn’t work, report your findings here:
Can I do it manually? Yes.
If the chains are still attached to your sled because you skipped other steps, please, skip this step.
Step 10: Enter Rotational Radius Estimate
In this step you will enter in a value for the rotational radius of your ring or linkage kit. So far, there are three main types of linkage kits:
  • Ring (now the stock kit shipped with Maslows)
  • Wooden Linkage (@PillagethenBurn’s kit)
  • Metal Linkage aka Top Pantogragh (@dlang’s kit)
Values are provided as estimates for these three kits. If you have better numbers, use them, if not, use the values provided. Notice the note about the values being rough and should be updated. Someday they will be.
Click “Enter Measurement” and enter the appropriate value.
Click “Next”
_What's the rotational radius?_ Rotational radius is the distance from the center of the router bit to where the chain ends (more precisely, it's to the middle of that first link..) It's basically the "extra" distance the program needs in order to calculate how much chain to feed out. If you have a custom built linkage kit, the radius could be different. But if you into it enough to build your own custom linkage kit, you probably aren't reading this.
Actually, this is a good step to skip as long as you have entered a good value during a previous calibration. Sometimes you are doing this calibration again just because you want to tweak something and if you skip this step, then the program will keep your existing value.
Step 11: Adjust Chain Lengths, aka "The Tricky One"
So, for this step, the lower left image differs based upon whether you are in “Chain Off Top” or “Chain Off Bottom” configuration. Here, we fork again…
  • If “Chain Off Top”, go to Step 11A
  • If “Chain Off Bottom”, go to step 11B
Step 11A: Adjust Chain Lengths - CHAIN OFF TOP ONLY
So if you are here, you should:
  1. Have the left chain still on the left sprocket with a bunch of it fed out over toward the right sprocket… and it’s probably still attached.
  2. The right chain is balled up in a tangled mess because you haven’t used it yet and kicked it a few times trying to do the previous steps.
The process here is not too complicated.
  1. Remove the left chain from the right sprocket. LEAVE IT WHERE IT IS ON THE LEFT SPROCKET
  2. Click “Adjust Left Chain” while holding on to the left chain… you don’t want it flopping around.
  3. The left sprocket will turn counter-clockwise and retract the chain to a determined length (suitable for connecting to the sled).
  4. When that’s done, place the right chain on the right sprocket as shown in the picture on the left. Basically its a mirrored image of the left chain when we first started the process to measure distance between motors in Step 5.
  5. Press “Adjust Right Chain”. GRAB THE CHAIN BEING FED OUT AND GIVE IT TENSION SO IT DOESN’T WRAP AROUND THE RIGHT SPROCKET. I don’t know about you, but if I don’t babysit my chains during this part, they are guaranteed to wrap around the sprocket. Don’t let that happen.
  6. When the right chain has stopped being fed out, connect the chains to your sled.
  7. Press “Move to Center” and hopefully if your measurements and estimate for rotational radius were close to what they should be, your sled will move close to the center.
  8. Press “Next”
My chains don’t reach the sled… whatsup? Most likely you have a 12-foot top beam (or at least you motor spacing is further apart than would be with a stock frame. You need to Go to Settings->Advanced Settings and set the Extend Chain Distance based upon the following:
The key to the setting is to make it a multiple of 63.5 mm and long enough so you can attach your chains to the sled when the time comes. If you have a 10-foot beam and they don’t reach, then your rotational radius or vertical measurement of motor height is probably wrong. Check those measurements and go back to correct.
My chains fell off the sprocket… whatsup? If you removed the left chain from the left sprocket and reset it so the first link is on the 12 o’clock tooth, you didn’t follow directions thereby causing the chain to fall off. At this step, the controller thinks the left chain is extended all the way to the right sprocket. So when you tell it to adjust, it’s going to retract the chain (turn counter clockwise) and if you had reset the chain, it’ll fall off pretty darn quick.
What you need to know to skip this step If you never removed the chains from your sled (i.e., skipped previous steps) then please, skip this step.
Step 11B: Adjust Chain Lengths - CHAIN OFF BOTTOM ONLY
  1. Your sprockets are pointing at 12 o’clock
  2. Your chains are not attached to either sprocket.
  1. Place the left chain on the left sprocket as shown in the picture on the left.
  2. Click “Adjust Left Chain” while holding on to the left chain… you don’t want it to wrap all the way around the sprocket and get tangled up.
  3. The left sprocket will turn counter-clockwise and extend the chain to a determined length (suitable for connecting to the sled).
  4. When that’s done, place the right chain on the right sprocket in a mirror image of what’s shown in the picture of the left. Here’s a picture just to be crystal clear:
image Yes, I took the picture and mirrored it.
  1. Press “Adjust Right Chain”. GRAB THE CHAIN BEING FED OUT AND GIVE IT TENSION SO IT DOESN’T WRAP AROUND THE RIGHT SPROCKET.
  2. When the right chain has stopped being fed out, connect the chains to your sled.
  3. Press “Move to Center” and hopefully if your measurements and estimate for rotational radius were close to what they should be, your sled will move close to the center.
  4. Press “Next”
My chains don’t reach the sled… whatsup? Most likely you have a 12-foot top beam (or at least you motor spacing is further apart than would be with a stock frame. You need to go to Settings->Advanced Settings and change Extend Chain Distance from the default of 1650 mm to something bigger. I think I used 2032 mm for 12-foot beam. If you have a 10-foot beam and they don’t reach, then your rotational radius or vertical measurement of motor height is probably wrong. Check those measurements and go back to correct.
placeholder
Placeholder 13
Placeholder 14
Placeholder 15
There are two steps 11A here. Obviously the second should be 11B. It only matters because on a small laptop screen it was hard to find.
